lojos 88w150 gas tank
Old Jul 13, 2018 | 12:30 PM
D@D88w150's Avatar
D@D88w150
Default lojos 88w150 gas tank
hi everyone been awhile ! back worken on daughters truck. looken for info on how to and whats needed to go from tbi back to carberator on 1988 w150 gas tank. can I use a pickup from a older gas tank and will it bolt right up or is there another way . also are gas tanks from long boxes the same size as a short box as we have a short box truck .any info would b great !! thanks again . for past help on this project.been fun
Old Jul 13, 2018 | 02:27 PM
Just put a regulator on it, to reduce fuel pressure to what the carb wants, and call it a day.
Old Jul 13, 2018 | 10:57 PM
crazzywolfie's Avatar
crazzywolfie
i think it would really depend on why you are swapping to carb. TBI is pretty simple and reliable compared to carb. even if it is going to be a hot rod i would recommend an aftermarket TBI setup. when carbs are working good they are ok but with how cheap aftermarket TBI setups are you are almost better off to go with one especially since your truck is already setup for it. they almost cost about twice what a new carb cost but usually get you better reliability and more consistent power since it is always learning and self tuning. short box tanks and long box tanks of the same year should be the same but i would almost shop for a 91-93 fuel tank if you are shopping since you can still get sending unit for them. 88-90 tanks are unique and have a 3 year only sending unit that is a nightmare to find if you ever need one.
Old Jul 14, 2018 | 10:38 AM
D@D88w150's Avatar
D@D88w150
thanks for fast response ! to answer why I don't just drop a sending unit in. I for got to mention need new tank cause somebody drilled a hole in bottom of this tank and haven't found a adequate way to patch. for the tbi answer I got this pickup with a blown computer plus blown motor .I had a 79 d300 duelly with 360 4 barrel only 45000 miles on engine sitting in pasture .got it all ready to rebuild with all parts already. daughter/father rebuild having a great time doing this with her! its been about a year since I been on site due to other commitments getting done. now have time to again to get this project complete before her 16th birthday in 9 months wish me luck and bloody knuckles !! thanks again for helping us out mopar rules!!!!!
Old Jul 14, 2018 | 01:44 PM
crazzywolfie
usually a clean drilled whole is pretty easy to have plastic welded but if you have a 80's carb tank it should work. the sending unit is in a bit different location and they are usually a bit smaller by 2 gallons but the filler whole and the bumps in the tank should be in the exact same locations. i don't know if a 70's truck would have the same tank as they used in the 80's
Old Jul 16, 2018 | 11:25 AM
D@D88w150's Avatar
D@D88w150
thanks for pic . so got tank out think I got what it takes to plastic weld as they say .question of the day. can I just drop in a pickup /sending unit from a carb tank into the tbi tank that i got and if so do i need to make any modifacations. thanks again for all the great info and hep!!
Old Jul 16, 2018 | 02:35 PM
crazzywolfie
a carb sending unit is not the same. you would be best to reuse the stock sending unit and just remove the fuel pump and run the fuel line to the bottom of the sending unit and add a strainer to keep it from sucking up any garbage.
Old Jul 16, 2018 | 06:03 PM
Or use the TBI fuel pump, and a three-port regulator. (one port is fuel return.)
Old Jul 16, 2018 | 06:49 PM
crazzywolfie
you would also need another oil pressure switch if you did that plus if the fuel pump hasn't been replaced it is bound to start dying soon if it hasn't already. the better and cheaper way would be to just run a line to the bottom of the tank or hook up to the fuel tank drain port and run that to the mechanical fuel pump.
Old Jul 17, 2018 | 11:14 AM
D@D88w150's Avatar
D@D88w150
thanks for replys awesome input .I think I will go with running the line to bottom of tank with a strainer fuel pump looks like a rusted nail lol .it must of sat dry for a very long time also . im just going to run a new fuel line with the way things look just to be done with no more problems. thanks again for all the feedback . next part is putting it all back together wish us luck ! and bloody knucklesl lol!
