replacing fender badges
Clean both surfaces with rubbing alcohol, let dry 60-90 seconds, then stick em on with good 3m double tape.
Word from the wise, take some tooth paste, goober them up so they stick where you want them, then use masking tape to underline it. You can also put a little marker tab to the bottom left of each letter to remind you exactly where you want them to go. So you get it perfect on the first try.
I had a 99 Ram that I put 2015 emblems on and did it this way. It really looks badass when you swap old emblems for the newer ones.
