Engine swap
Old Aug 8, 2018 | 12:34 AM
freemanbest5's Avatar
freemanbest5
Default Engine swap
1990 Dodge W150 pickup 5.2 318.
recently had the tranny rebuilt. I keep having issues with the motor and I'd just like to replace the motor. What would be the best motor to swap into? I would have a shop do the work. Crate motor?
Old Aug 8, 2018 | 04:24 AM
Shepard929's Avatar
Shepard929
The “best” would be a fuel injected magnum motor, like what the late 90’s one had.
it really comes down to what you want to spend, but depending on what issues your having with your 318, you might be happier having it built, or swapping it with the 360. I’m pretty sure the 360 should easily bolt up to the same tranny.
Old Aug 8, 2018 | 06:28 AM
Moparite's Avatar
Moparite
Put in a magnum motor, You can make it work with the TB injection that's on the truck.
http://www.magnumswap.com/first-steps/
Old Aug 8, 2018 | 11:11 AM
freemanbest5
Default how to
Do I look for a motor from a junkyard or find a company that already has remanufactures motors? What do remanufactured motors cost?
Old Aug 8, 2018 | 01:49 PM
Depends on how much you wanna spend.... and if you want it stock or not. You can spend anywhere from 1500, up to 15000 on a reman motor.......
