Will a 1977 grill fit on a 1985
Old Sep 23, 2018 | 11:33 PM
Dale Plante's Avatar
Dale Plante
Default Will a 1977 grill fit on a 1985
What would i need to pull this off
rad core forsure. Will the lower grill line up with the 85's fenders?
Old Oct 3, 2018 | 09:43 AM
Noelie84's Avatar
Noelie84
You probably could get it to bolt on, but the lines won't match up correctly at the fenders and possibly the hood. Plus you'll run into problems with the radiator core support; if you use the 70's core support it won't fit with the fenders without some cutting & welding, and if you use the 80's core support the headlights will be in the wrong place.
Old Oct 3, 2018 | 01:55 PM
Dale Plante
1985 with a 1979 core support and grill
Core support
Old Oct 3, 2018 | 01:57 PM
Dale Plante
Default Pre swap
Pre swap
Old Oct 3, 2018 | 03:10 PM
Noelie84's Avatar
Noelie84
Core support
Did you have to tweak the radiator support to make it work? I thought that the 70's version had different connection points to the fenders than the 80's version.
Old Oct 3, 2018 | 03:18 PM
Dale Plante
Default Fender holes line up
The old 80's head lights bezels are longer then the tin grills of the 70's so there is a small body line and hole from where the square bezels should be.
I will be getting 70's quarter panels and mig welding in the the 80's wheel arches onto them
Old Oct 4, 2018 | 11:48 AM
Noelie84's Avatar
Noelie84
Sweet. 2 internet points for creativity.
