92 dodge transmission
Old Apr 4, 2019 | 01:27 PM
Michael Flewelling's Avatar
Michael Flewelling
Default 92 dodge transmission
I have a 92 dodge w150 with the 318 Od 4x4 and was told that it was the 46rh transmission.
I found a 90 ramcharger 318 od 4x4 with the 518 trans.
Will the ramcharger trans fit in my w150?
Old Apr 4, 2019 | 05:52 PM
I think its the same trans, just different nomenclature.
Old Apr 4, 2019 | 09:01 PM
crazzywolfie's Avatar
crazzywolfie
are they sure it is a 518 and not a 500? you may also want to see if it as a 2 or 3 pin overdrive connector. there is a chance it may be a early setup without lockup torque converter. there is also a chance the bell housing may not be notched for a crank position sensor. either way it should probably fit.
