Starter swap
Old Apr 23, 2019 | 12:19 PM
Jesse Brezden's Avatar
Jesse Brezden
Default Starter swap
I have two dodges a 85 dodge 318 and a 98 dodge 318. The motor is blown in my 98 and the starter in my 85 is gone. Question is? Can I put the starter from my 98 into my 85?
Old Apr 23, 2019 | 12:25 PM
crazzywolfie's Avatar
crazzywolfie
yes it will work. there is a chance you might need to use the starter wires from the 98 but you will find out pretty quick. the 98 starter will go into your 85 quicker than you will get the starter out of the 85
Old Apr 23, 2019 | 02:59 PM
Jesse Brezden
I go the starters swapped and same issue the truck won’t even turn over no power going to the starter the battery is new any idea??
Old Apr 23, 2019 | 05:45 PM
Do you have power at the fat cable at the starter? If you do, next, need to see if the solenoid gets power when you turn the key. (my guess is: No.) Manual or auto trans?
Old Apr 23, 2019 | 06:23 PM
crazzywolfie
did the starter wire get pulled off the starter relay? it is the brown 1 that goes to the starter relay.
