Screw in Ball Joint a litle screwed
on
Well, just got around to reinstalling the upper ball joints. Read the instruction leaflet that came with the new ball joints, it suggested not to cross thread the ball joints on installation. Thats good advice I thought to myself.
Commenced installing the ball joint, found it tight going in but figured thats OK since they were tough to get out. Got almost home and discovered it was cross threaded. DAMN, Unscrewed it til it was loose, got out the plastic hammer and tapped it back straight, screwed it home but was not a nice tight fit.
Now I'm wondering where to go from here. Will it be OK as is, should I get a new control arm and start again. is if feasible to tac weld the ball joint body to the control arm to make sure it stays put.
Open to suggestions.
Thanks
Thanks
if you can tighten it anymore that would be the best route to go but if not a tac weld will do the job. if upper control arms were readily as an aftermarket part i would say replace it but i know they are not as readily available anymore and the price asked for them is usually reflected by availability. i don't think there is really that much stress put on the upper control arm which is why it is so scrawny compared to the lower control arm.
