LED blinkers and taillights problems
So I ordered led bulbs to go all around my truck and my first problem was the taillights... the taillights didn’t work but when I pressed the brake they lit up and the other problems are the front blinkers they work fine when I turn the lights on but when I went into my truck the blinker arrows for both sides stayed on like I had a blown bulb or something. Has anyone ran into this problem and is there a way I can fix it so I don’t waste my money on all these leds?
a electronic flasher won't fix the issue but will be needed to make things work. you will most likely need to install diodes on both front turn signals and marker lights to keep power from feeding from 1 system into the other. i don't know if you can use led's on the side without choosing whether you would like them to work as marker lights or turn signals since they can't usually work as both with led's. you pretty much need a a/c light bulb in there and i don't know of any other than the stock bulbs.
The following users liked this post:
Dustinyourshelf (02-16-2020)
