Missing Emissions Equipment 1983 W250 318 4 barrel
Old Oct 22, 2020 | 06:09 AM
ol' grouch's Avatar
ol' grouch
Originally Posted by James Jamie Soule
Thanks ol grouch! Will follow the booster line to see whats there. I need to pull the air cleaner for painting and freshing up as I just did the valve covers when I resealed them -time to clean the intake, degrease and paint. With the AC off, I can see whats on the back side of the carburetor - almost need a scaffold just to get back there!
Why not take a picture of your engine top from the side? That will refresh my mind as to particulars. As for working on it, I've been known to climb inside and sit on the fender to work on them. On my old '84, I got some brackets made to move the bumper out 6 inches. I put a metal plate behind it and stood on it to work on the engine. It was also handy to mount fog lights.
Old Oct 22, 2020 | 11:23 AM
volaredon's Avatar
volaredon
Vac advance usually runs from ported vacuum. I'd just run a line from where it connects to the carb on the other side of the ported vacuum switch straight to the distributor
Old Oct 22, 2020 | 11:45 AM
James Jamie Soule's Avatar
James Jamie Soule
Thats what I was thinking, that vac switch at Tstat housing would be a good spot for water temp gauge.
