Freeze Plug Locations
Old Dec 11, 2020 | 03:25 PM
MoparMax's Avatar
MoparMax
Default Freeze Plug Locations
Hey guys, where can I find a diagram or picture of all of the freeze plug locations including the heads? Thanks fellas
Old Dec 12, 2020 | 07:35 AM
Moparite's Avatar
Moparite
What motor? LA has three on each side of the block and two in each head. Two in front and behind the block also.
Old Dec 13, 2020 | 10:47 AM
MoparMax's Avatar
MoparMax
Moparite,
It is the 318, last night my son and I pulled off the water pump thinking that is what was leaking, there is coolant dripping down the edge of the timing cover where it meets the front of the block on the passenger side. This motor is original and has 490K miles on it, but Dodge skipped out on putting quality freeze plugs in during the build process and I've spent more time than I care to replacing them over the years. Where or for what reason in that area would it be leaking? Thanks.
Old Dec 13, 2020 | 10:57 AM
Timing cover......
Old Dec 14, 2020 | 01:27 PM
Moparite's Avatar
Moparite
You will need to replace the timing cover gasket. And if you want good freeze plugs get the brass ones.
