1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hi. I had to jump start my 93 w250 and now i have power to everything and my truck turns over, but will not fire up. I have a electric pump and it will/was running. So there is no air in the injectors. Please help
somewhat of a universally present happenstance when jumping a vehicle especially older ones. You can pop fuses or even a “main relay” so check all your fuses and such then check back in with what’cha find. Because that main relay is in charge of running your ECU and most likely your ignition
Shoot a little starting fluid into the intake. If it still doesn't start, you aren't getting spark. If it starts then dies, you're not getting fuel. Quick way to eliminate possibilities.
The truck turns over and has fuel. I will spray some starter fluid to see if it fires up
if you know you have fuel, I’d avoid starting fluid. It can wash down the cylinder walls if your aren’t careful and cause scoring.
I genuinely believe if you check your ignition related fuses and whatever serves as the main relay/fuse for your ECU/PCM (whichever acronym they use for that year) it will be popped.
Thanks for all the help. I sprayed some starting fluid and it started. I found a loose wire on the fuel shut off. Replaced the worn connector and it starts. Thanks again
Loose wires and bad grounds cause more aggravation than anything else.
