Engine Swap 318LA Rebuild questions.
Old Jul 19, 2021 | 01:17 PM
Maki's Avatar
Maki
Default Engine Swap 318LA Rebuild questions.
I've got an 87 318 from a D150 with an auto trans to swap into my 88 and I was wondering if anyone is able to tell me exactly what I need for a rebuild and to remove the Smog system during the rebuild. I figure I'll just pick up a general rebuild kit for the seals and such.
Old Jul 20, 2021 | 06:11 AM
Moparite's Avatar
Moparite
Impossible to tell with out taking the motor apart.
Old Jul 31, 2021 | 09:44 PM
Maki's Avatar
Maki
I figured as much but was hoping someone more experienced might've had a trick to it.
Do you know if the 87 5.2l and the 88 3.9l had the same transmission hooked up behind it? I ran them through the Decoder, but it doesn't tell me what Trans was in it, just the engine. Both are 2WD Auto's. I didn't see that info on the door stickers either
EDIT: Doesn't much matter. Going to sell off my 5.2 and save up for one of those sick 500CI Turnkeys, and figure out which transmission once I've got that.
Old Aug 3, 2021 | 11:19 PM
crazzywolfie's Avatar
crazzywolfie
https://dodgeforum.com/forum/1st-gen...ml#post2961550
