1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Does anyone have the dimensions of the 79/80 dual headlight bezel? I know the buckets will bolt in without changing the grill, but I'm hoping I can squeeze the bezels in without changing the grill as I like the one on the 88.
An 88 the yellow turn/marker light is part of the bezel, the duel light bezel for the 79/80 was just the piece that goes around the two headlights. I suppose it's possible to hack the 88 to fit.
Originally Posted by u2slow
I suspect the rad support will need some modification for the lamps.
I know between my 84 and 89-90's the headlight height changes and bezels do not swap.
Damn, my plan was to ditch the 88 bezels and swap the buckets and bezels in and run my turn signal in one of those fancy new LED headlights to cover my *** for the laws. Doesn't seem like it'll play nice without making some custom trim pieces to tie them together, which I was trying to avoid.
