89 D100 will not start
Old Nov 1, 2021 | 08:10 PM
cudapop's Avatar
cudapop
Default 89 D100 will not start
I could use any and all suggestions. I have 1989 d100 with 5.2 (318) that will not fire. If I prime the TBI with carb cleaner it will run. I have fuel pressure all the way to the TBI. I tested the injector wires with a noid tester and they are working. I replaced the injectors and I tested them as well and they are working. I replaced the pressure regulator and still not starting. Thank You.
Old Nov 2, 2021 | 06:19 AM
Moparite's Avatar
Moparite
What psi?
Are they squirting fuel? Have someone look down the throttle body when you turn the key to on. The pump will prime the system and squirt some fuel in the tb.
Old Nov 2, 2021 | 02:10 PM
cudapop's Avatar
cudapop
No they are not squirting fuel
Old Nov 2, 2021 | 07:34 PM
ol' grouch's Avatar
ol' grouch
I'm not sure how the pre-Magnum engines did their fuel injection but something isn't telling the injectors to fire. Probably a crank or cam sensor, but I've never worked on trucks of that vintage.
Old Nov 3, 2021 | 06:37 PM
crazzywolfie's Avatar
crazzywolfie
before replacing the fuel injectors did you make sure the fuel passages were clear? also how did the screens on the old injectors look?
Old Nov 9, 2021 | 09:50 AM
cudapop's Avatar
cudapop
It did not have enough fuel pressure...replaced fuel pump and it started.
