Cab questions
So long as they are the same style. (both extended cabs, for example) You will have to make some changes for the t-case shifter though. It *might* be a panel that just bolts in, but, more likely, you will have to cut some holes.
A 2wd auto std cab has a different (lower height) trans tunnel than the rest. On my 84-93 trucks, the tunnel is part of the floor stamping - not removable. It is an area that could be cut out of one cab and spliced into another. A body lift might make it work too.
