1986 dodge d250 no headlights
Old 05-15-2022 | 07:16 PM
andrewjthomas's Avatar
andrewjthomas
Default 1986 dodge d250 no headlights
After coming home from work one day I shut off my headlights and went inside the house. When I came out to go to work the next day both sets of lights didn't come on. Fog and turn signal lights still work for front and back. Just the headlights don't work. I have LED headlights installed. What could be causing this? some people have said that it could be the fuse or switch. But the switch still works for the fog lights... also brights do not work.
Thanks.
Old 05-15-2022 | 10:23 PM
ol' grouch's Avatar
ol' grouch
Thanks.
Do you have the high/low beam switch on the floor or the turn signal stalk? Sometime in the late 80's they moved it from the floor. If it's on the floor, I'd pull it and see if it can be cleaned. It's just a couple of screws and one plug.They aren't very expensive, just finding one might be an issue with most parts stores cutting back on what they stock.
Quick Reply: 1986 dodge d250 no headlights
