1985 Dodge Ram manual swap
Old Jun 18, 2022 | 09:21 PM
Sammy@85d150's Avatar
Sammy@85d150
Default 1985 Dodge Ram manual swap
I have a 85 dodge d150 with a 318 LA, and behind it is a a727 automatic transmission. I want to swap it with a nv3500 from a 2001 Dodge Ram with a 5.2l V8 how would I go about this never manual swapped anything before
Old Jun 19, 2022 | 04:50 PM
u2slow's Avatar
u2slow
I suspect you'll want the 89-93 hydraulic clutch pedal assembly to make things easiest. Flywheel (LA 318 balance). Hopefully the 2001 clutch fits. Locate and modify the trans crossmember to work. Shorten/lengthen the driveshaft as needed.
