Ready Sleeve For Rear Axle Wheel Seal
Old Aug 9, 2022 | 09:58 PM
DodgeDriver123's Avatar
DodgeDriver123
Default Ready Sleeve For Rear Axle Wheel Seal
I have a 1989 dodge d350 dually and the passenger side wheel seal is leaking and I replace it once already and it continued to leak so I looked at the sealing surface and its a little rough, so I was wondering what the part number or where to get a ready sleeve for my truck. I don't know what axle I have other than it has a 3 inch shaft diameter for the sealing surface (part description for the seal says shaft diameter 3.0 in) on the axle.
Old Aug 10, 2022 | 07:15 AM
I have had no success with the sleeves on harmonic balancers..... (the most common use for them.) In your case, I do believe that part just bolts to the axle, I would be tempted to simply replace it.
Old Aug 10, 2022 | 11:46 AM
crazzywolfie's Avatar
crazzywolfie
https://www.dieseltruckresource.com/...0/#post2348051
