Steering shaft replacement
Looking to replace the steering box and shaft on my ‘92 w150. It has a 318 and a 5 speed if that turns out to be relevant for whatever reason. Heard good things about the redhead steering box and borgeson shaft so I ordered those and a rag joint. Now that I’m looking at my truck though, it doesn’t appear to have a rag joint. The shaft coming down from the column has splines on it just like the shaft on the stock steering box. So I assume I have the wrong steering shaft, but I don’t see any for first gens that connect to splines on both ends. They sell them for second gen trucks but the steering shafts they have marked to fit a first gen are supposed to connect to the column with a rag joint. Anybody have input on this? Did they change up the way it connects for the last few years of the first gen or something?
If i remember correctly they use a steering coupler, Should look like this. You may want to inspect it also because it can wear and can cause slop in the steering.
you need steering shaft 000940. you can buy knock of ones for much cheaper on ebay
https://www.borgeson.com/Dodge-Truck...dge-Truck.html
