Help identify this part so I can buy a replacement
Old Jan 2, 2023 | 03:39 PM
jholaway1971's Avatar
jholaway1971
Default Help identify this part so I can buy a replacement
I know it's a power steering pump but what is attached to it so I can order another sealThis is on a 93 350 Cummings diesel engine
Old Jan 2, 2023 | 05:56 PM
u2slow's Avatar
u2slow
It's the vacuum pump. The coupling between the two is dry - no seal. There is a big gasket between the vac pump and timing cover. It can usually be reused.
Old Jan 3, 2023 | 01:41 AM
jholaway1971
If there is no seal how do I get it to stop leaking?
Old Jan 3, 2023 | 10:03 AM
crazzywolfie's Avatar
crazzywolfie
Old Jan 3, 2023 | 03:32 PM
u2slow's Avatar
u2slow
I meant you can unbolt the ps pump without losing it's fluid
Old Jan 3, 2023 | 04:35 PM
jholaway1971
Those were videos for 2nd generation trucks, mine is a 1st generation truck
Old Jan 3, 2023 | 10:44 PM
crazzywolfie
its the same thing. the only thing that changed on the 2nd gens was the injection pump. clearly the other link got merged into the youtube video but you can just get another vacuum pump from rockauto if you would rather just replace it instead of rebuilding it.
https://www.rockauto.com/en/catalog/...cuum+pump,5172
Old Jan 4, 2023 | 05:14 PM
u2slow's Avatar
u2slow
Afaik, 91-98 (and perhaps beyond) use the same vac and ps pump (aside from an extra ps fitting for hydro boost).
The 89-90 vac pump is a different animal with two large diaphragm pods. Many trucks get updated to the new style.
Old May 17, 2023 | 03:58 AM
ArronGonzales's Avatar
ArronGonzales
Thanks for the link, you made my day. When I was seeking for places where I could play the greatest new casino games, I stumbled onto this https://casinosanalyzer.ca/online-casinos/new-casinos site. On this website, I discovered online casinos and gambling sites. The same games are available to players at new online casinos as at existing ones.
