92(IC) 12 valve
Old Apr 22, 2023 | 05:03 PM
BM9NBA2's Avatar
BM9NBA2
Default 92(IC) 12 valve
Hey fellas so I wrapped up on Wednesday with the kdp, timing case bolts, front main, water pump, thermostat, coolant system flush, new radiator, and new CAT coolant with distilled water . Not sure why, but so far have only been able to fit a little over 4 gallons(16.5 qts) in the system, but about 20 quarts came out for first initial drain of the system. It's been taking a little bit from the Coolant overflow, but very little. The coolant was a bit brutal that came out for the first drain and then I used blue devil coolant flush with water to flush the system.
Old Apr 22, 2023 | 05:49 PM
BM9NBA2's Avatar
BM9NBA2
I had decided to leave the old thermostat in for the flush and replaced it afterwards this way when I drained the flush out I ran the hose against the block where the thermostat would be to get everything else out. So the block should've been empty. I let the flush run through the system for about an hour and a half which it took like an hour for her to warm up anyways(no grid heater or ksb) then drove the truck for a few minutes and let the coolant flush sit for about 2 hours while the truck was cooling down.
Old Apr 22, 2023 | 06:36 PM
There will always be some in the block. If you run it, the thermostat opens, and the level doesn't really go down, it's full. Keep an eye on it for a couple days, and if level stays good, yer done.
Old Apr 22, 2023 | 06:44 PM
BM9NBA2's Avatar
BM9NBA2
Alright yea I just had hoped I had gotten all the old coolant out, but it is what it is. The temp shows that its insanely lower now on the gauge which is a good thing I guess because it must be cooling a lot better, but I used my temp gun and it's at the proper thermostat temp 180°F by cylinder #6. I had thought the thermostat was stuck open once I seen the gauge, but its not. Next year I'm probably gonna take the lower water housing off anyways and check inside there to see how it looks and replace the oil cooler also and oil cooler gaskets while I'm there so will flush the system again then.
Old Apr 25, 2023 | 04:52 PM
William Scott's Avatar
William Scott
what coolant do you actually use ?
Old Apr 25, 2023 | 05:44 PM
BM9NBA2's Avatar
BM9NBA2
Caterpillar coolant ELC ec-1
