Dana 44 Spindle
Old May 16, 2023 | 10:22 AM
jtpasto's Avatar
jtpasto
Default Dana 44 Spindle
I have a 1987 Dodge W250 Dana 44 front axle with axle disconnect. The right spindle has a roller bearing and the left spindle has a spacer (no roller bearing). Does anyone know the part number and where I can purchase a spacer? Someone installed a roller bearing in the left spindle and it is all chewed up.
Old May 20, 2023 | 05:42 PM
u2slow's Avatar
u2slow
Parts specific to our CAD front axles aren't really supported. May have to find a used one.... which may lead you a whole diff, possibly an older non-cad unit. Then you can mix n match parts and use a normal bearing on the spindle.
Old May 21, 2023 | 08:52 AM
Moparite's Avatar
Moparite
Look up your axle via a dana pdf, I have one and it shows there where two types. Are the bearing/spacer in the hub? The only spacer i see is this one.
Old May 21, 2023 | 10:04 AM
jtpasto's Avatar
jtpasto
The bearing spacer is in the spindle. Since there is a bearing at the end of the axle tube, they eliminate the bearing in the spindle. The spacer is used to support / position the seal.
