1987 Dodge W250 Front Axle Disconnect
Old Aug 16, 2023 | 02:57 PM
jtpasto's Avatar
jtpasto
Default 1987 Dodge W250 Front Axle Disconnect
The vacuum line, on my 1987 Dodge W250, that operates the front axle disconnect is not hooked up. The engine is a 318. I have not found an obvious vacuum connection point on the back of the engine. Does it make a difference whether the vacuum line is connected to the intake manifold or the base of the carburetor?
Old Aug 16, 2023 | 06:13 PM
Yes. You want manifold vacuum for the 4x4, the port on the carb might 'ported vacuum', which is the exact opposite of manifold vacuum.
