1985 w250 4x4 won’t engage
Old Nov 25, 2023 | 04:51 PM
Davemcdonald71's Avatar
Davemcdonald71
Default 1985 w250 4x4 won’t engage
Just rebuilt my truck last winter, it worked before that. I had it up yesterday all wheels off the ground and put it in 4 low and only drivers side rear tire was spinning. It’s an automatic transmission with automatic hub lock( hub is sealed)
Old Nov 25, 2023 | 07:39 PM
If you have an open rear diff, then what you see there is normal. Apply the brake a bit, and the other rear tire should start spinning as well. As for the fronts, probably the hubs just aren't locking in. Is the front driveshaft turning?
Old Nov 26, 2023 | 11:49 AM
ol' grouch's Avatar
ol' grouch
Is the vacuum line to the front actuator good and attached?
