dashboard left turn signal bulb and more stuff
1992 Dodge D150 Ram Truck problem Turn Signals:
The left turn signal works only when the lever is held in a specific position (jiggled and pushed slightly towards the center).
I removed the left turn signal bulb from the dashboard and instead of being clear it has a silver looking burned out bulb look
- The left turn signal front and rear flashes slower than the right turn signal. The left Dash board instrament panel light bulb burned out
- Lightbulbs:
- The left dashboard light is not working.
- The hazard lights (flashing all four turn signals) do not work, even though the front turn signals work normally with the hazard switch engaged.
- I swapped the left turn signal bulb with another bulb, but the turn signal indicator remained off.
- I removed the taillight lens and checked the bulb connection for the hazard lights. After fiddling with it, the hazard lights worked temporarily, but stopped again when I reassembled the taillight.
- Where can I buy new dashboard light ? what is wrong I am a person who knows almost nothing about wiring / electrical car maintanance.
- Any advice would be greatly appretiated thanks
