Brake pressure problems
Old Nov 14, 2024 | 06:18 PM
Kinderkin's Avatar
Kinderkin
Default Brake pressure problems
I replaced the shoes and rear wheel cylinders blood them several times had brake pressure . Thrn I replaced the brake check valve on the booster after starting the truck did not have adequate brake pressure???????
Old Nov 14, 2024 | 07:16 PM
Is that the vacuum check valve on the booster??
Did you adjust the rear brakes??
Old Nov 14, 2024 | 07:32 PM
Kinderkin's Avatar
Kinderkin
The check valve is on the brake booster and yes I drove the vehicle in Reverse to adjust the rear brakes
Old Nov 15, 2024 | 07:38 AM
That method will take quite a while to get them adjusted properly. That's why there are little 'windows' in the backing plate, so you can manually adjust them after a brake job.
Old Nov 16, 2024 | 09:46 AM
Moparite's Avatar
Moparite
AKA the black push in plug for the "window" at the bottom of the backing plate. You need a "brake tool" or screwdriver to adjust the star wheel until you feel resistance. I'm sure there are videos on you tube that show you how to do this.
