73 D100 318 Oil pressure question
Old Dec 8, 2024 | 09:39 AM
Moparite's Avatar
Moparite
The OP hasn't been back since his one post. Would be nice to know details to give an informed opinion.
Old Dec 8, 2024 | 05:22 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by Los_Control
@ol' grouch maybe I'm just looking at things wrong or not explaining myself to original poster .... My first post I suggested to hookup a mechanical gauge if you want to know what your oil pressure is.
Let me try to explain it this way .... I'm slow, I should have thought of this earlier.
I have a daily driver 1991 chebby truck with a 350 and have driven it since 2018. It has a oil pressure gauge with a sending unit. I can tell you the gauge rides from middle to slightly above ... it actually does move a bit when above idle.
Maybe I watch too many Hot Rodders on youtube .... I do not want to race, but interested in watching others build their cars and race them.
With a stock oil pump they can run the top end on the dry side when wound up to 6K rpm going down the 1/4 mile.
Or with a high volume pump and a stock pan they might run low on oil on the bottom end .... A deep sump pan fixes that.
Extreme cases but that is what I think about ... it applies to me if am out on a back dirt road and get stuck in the mud or snow and try revving the motor to get out .... I'm fine with a stock pump.
High volume pump is a tool to be used in the right places.
I've nearly come out of my chair more than once watching motor head programming. One show that builds stuff from scratch might be good fabricators, but not very good, well, at least SAFE, mechanics. The host preaches that you must unhook the positive cable to be safe. That's a good way to burn a car to the ground. You disconnect the negative to disable the electrical system. Unhooking the positive with the negative still in circuit can lead to a dead short.
Old Dec 16, 2024 | 12:13 PM
dog1974's Avatar
dog1974
I think the 28 psi sounds great at hot idle, 25 would be fine .... if it was 20 ... well she aint no spring chicken but she does just fine ..... Some older engines from the 50's 5 psi at hot idle is fine.
Typically low oil pressure at idle is from worn bearings. ..... I would not call 28 psi at hot idle low. I would call that fine.
So what the heck is going on with 40psi at hot idle? Is this a brand new rebuilt with new bearings and just getting broke in? ... 40 seems high ... unless you have a high volume oil pump for racing .... which is a bad idea.
Are you sure your gauge and sender are correct? .... I would like to check it with a mechanical gauge to see if they match.
Curious what readings you get cruising at 50 mph.
i think i might be going insane then cause it’s not showing 40 psi so i may have just looked at it wrong when i saw 40 psi. and at 50 it’s at 32-34 psi from what the gauge says.
Old Dec 16, 2024 | 12:14 PM
dog1974's Avatar
dog1974
my apologies i’ve forgotten i got adhd and also been busy. i’ve been meaning to be back haha.
Old Dec 16, 2024 | 12:16 PM
dog1974's Avatar
dog1974
How may miles on the motor and what weight oil is in it? Cold and hot psi. Idle and at rpm.
it’s rolled over at least once with me and i’m the 3rd owner so at least 110k miles at least. and i’ll get a cold psi reading after work when the engines cold. it’s got 10w-30
Old Dec 16, 2024 | 01:59 PM
Los_Control's Avatar
Los_Control
All I'm suggesting, do not read too much into the reading. .... Here is my gauge, it appears to be reading 40psi cold ... it reads the same when warm.
True oil pressure will be higher when cold, then lower as the oil warms up and thins out ..... That tells me the gauge is not true or accurate. It does tell me I have oil pressure and the engine sounds happy.
Hey this is fine .... 40psi is not correct ... but I have oil pressure. ... this style of gauge is not usually accurate and not expected to be .... it does provide some info though.
If I connected a good manual gauge to it, I would probably have around 25psi or so and be happy with that.
