4 Wheel Drive Light Indicator Smoking-Help!
Old Mar 13, 2025 | 10:56 PM
James Jamie Soule's Avatar
James Jamie Soule
Default 4 Wheel Drive Light Indicator Smoking-Help!
Many months ago, I removed my dash instrument fascia panel and updated dash lights with LED's - when I plug in the four wheel drive light indicator into it's harness, the unit starts overheating immediately and starts to smoke! I put a meter on the plug and found 14.81 volts coming in on one of the five sockets! What would I have this much voltage? Bad ground somewhere? My lamp takes 3 bulbs (158's) which each have 3.4 watts - bulbs should be correct, I just can't figure out what is going on with the indicator lamp -any ideas? I would like to have this functioning again as I am selling this '83W250 -Help!
Old Mar 14, 2025 | 06:10 AM
Moparite's Avatar
Moparite
153's you can plug in either way, led's are diodes. Diodes allow power to flow only in one direction. You probably have them in wrong.
Old Mar 14, 2025 | 09:18 AM
James Jamie Soule
Thanks, but I took out the led's (from the sockets for the wheel drive light indicator) and put the 158 bulbs back in and still got the same result - the other led's are still in the instrument panel and do just fine (no smoking)
Old Mar 15, 2025 | 11:01 AM
Moparite's Avatar
Moparite
In that case something is shorted.
Old Mar 15, 2025 | 01:16 PM
James Jamie Soule
Thanks, so I guess from here, all I can do is trace that harness to find the short - much appreciated!
Old Mar 19, 2025 | 07:56 AM
James Jamie Soule
Apparently, 14.7 volts is fine at the socket that feeds the 4wdrive indicator hub locked light - I think what I have is a bad circuit board. Anyone have one floating around that they wish to sell? Mine is the 3 bulb style, thanks!
