88 D100 valve breather
Old Apr 14, 2025 | 07:25 AM
Donnie Underwood's Avatar
Donnie Underwood
Default 88 D100 valve breather
Looking to simplify the 318 TBI I have. It runs good, but no sense in having things that I don't need if by removing them, I'm not damaging or negatively impacting the engine or its performance. My ECM works fine and at this point, I don't want to tinker with it. That'll be another day when I look to remove the smog pump, EGR, etc.
The passenger side valve cover breather has an air hose connected into the air filter housing unit as originally built. Will it be harmful if I plug the hole in the air filter housing & do away with the hose to the valve cover breather and replacing stock breather with a stand-alone breather filter that does not need the hose
Thoughts?
Old Apr 14, 2025 | 07:48 AM
Shouldn't matter. So long as the air gets filtered before it goes into the engine, that's all you really care about.
Old Apr 15, 2025 | 10:18 AM
Donnie Underwood
Thanks. I pulled it yesterday & replace it with a stand alone crankcase breather filter. Just left the port open to the air filter housing for now. Runs just fine.
Old Apr 15, 2025 | 12:28 PM
You wanna plug that port. I believe that is post-air filter, and as such, the engine will pull unfiltered air thru that port.
Old Apr 15, 2025 | 01:38 PM
Donnie Underwood
I have been thinking about that. Plug it or clap a small filter on it. Whatcha think?
Thanks for your help
Old Apr 15, 2025 | 02:27 PM
I think I would just put a cap on it. Quick, painless, and easy.
Old Apr 15, 2025 | 02:29 PM
Donnie Underwood
10-4 sir
Thank you
