Bird bath hood question.
Old May 5, 2025 | 07:23 AM
Auslander's Avatar
Auslander
Default Bird bath hood question.
Found a 1976 bird bath hood. My question: Will it fit on my 1990 D150 with a dented hood? (Falling tree branch)
Old May 5, 2025 | 10:35 PM
ol' grouch's Avatar
ol' grouch
Only if you swap the 1976 grill assembly. The 1980's and later hoods fold down at the front. The '76 is flatter.
Old May 6, 2025 | 10:09 AM
u2slow's Avatar
u2slow
Think you need the matching cowl cover also (between hood and windshield.)
Old May 6, 2025 | 03:22 PM
ol' grouch's Avatar
ol' grouch
The more I think about it, the fenders might be different too. That would mean swapping the dog house between the two trucks. I'm thinking that might be pretty cool.
Old May 6, 2025 | 04:29 PM
Auslander's Avatar
Auslander
But then, don't i have to swap the radiator core support because of the headlight buckers?
Old May 6, 2025 | 06:16 PM
ol' grouch's Avatar
ol' grouch
The radiator support isn't that bad to pull. When the engine in my '84 W150 finally gave out (323K miles, you'd think they would last longer) the truck sat to high I couldn't life the engine high enough to clear the radiator support. I pull the support and brough the engine straight forward. I'm trying to think if the fenders will match up with the doors.
Old May 6, 2025 | 06:36 PM
Moparite's Avatar
Moparite
I've seen all kind of configurations when people mix and match years. I never really understood it! 70's body with 81+ front end or vice versa or whatever they could piece together.
Old May 7, 2025 | 09:33 AM
u2slow's Avatar
u2slow
The fenders are slightly different, but fit. The trick is an 80's door has a body line that may catch the 70's fender edge when opening.
Mixing and matching nose/grilles/etc is often a case of using what you have, or can find easy. As you know, these dodges aren't well supported in the aftermarket.
Old May 8, 2025 | 09:24 PM
ol' grouch's Avatar
ol' grouch
You work with what you have. I've got a '55 Chrysler I just pulled home. I'm using stuff I've had stashed for years. Popping down to AutoZone for parts on a 70 year old car can be problematic.
