3.90 Ring and Pinion Gears
Old Apr 27, 2006 | 03:31 AM
outlaws318's Avatar
outlaws318
Default 3.90 Ring and Pinion Gears
Looking for 3.90 gears for my 8 3/8 rear end. I have 3.55 right now are not doing to job off the line. Richmond Gears has 3.91 for $264.00, thats a little to much for me. Need alittle bit of help. Thanks
Old Apr 27, 2006 | 07:10 AM
horatio102's Avatar
horatio102
Default RE: 3.90 Ring and Pinion Gears
Should be about 200-210 for the ring/pinion only, plus more for the install kit. And I assume you're not going to install it yourself so you can count on it costing about $500 all said and done. Which casing do you have? It makes a difference. I recommend going to the install shop and getting a quote. If it's more than $500, figure out why. If the parts are too much, get them elsewhere.
Where do you buy axle parts? www.ringpinion.com should be your first answer. Give them a call.
Where do you get your other performance parts? www.summitracing.com again should be your first answer. You might find slightly better prices elsewhere, but the service can't be beat.
Old Apr 28, 2006 | 09:43 PM
outlaws318's Avatar
outlaws318
Thanks. Yes I'm going to do it my self because I don't trust the shop where I live. They think that if your in the army you have all this money, so they try to rape you on the price. So I'll do it my self.
Old Apr 29, 2006 | 05:57 AM
horatio102's Avatar
horatio102
Have you done one before?
Old Apr 29, 2006 | 12:31 PM
ugotit's Avatar
ugotit
We have the gears and install kits your looking for in stock we can beat Summits prices for Dodge Fourm memers,if you have any question email us at sales@strippermotorsports.com
Old Apr 29, 2006 | 03:51 PM
outlaws318's Avatar
outlaws318
No not yet, but my Uncle has built many of car from ground up. So he said he'll help me with it.
Old Apr 29, 2006 | 03:54 PM
outlaws318's Avatar
outlaws318
I find a couple of places with Gears. Drive Train Warehouse wants $275.00 for 3.91, and DTS wants $235.00 for 3.90, and Jeg's wants $389.88 for 3.90.
Old Apr 30, 2006 | 01:08 AM
horatio102's Avatar
horatio102
Through Summit:
Richmond Gear Sportsman 3.90/4.10 - 187.95
Superior Axle 3.90/4.10 - 229.95
Mopar Performance 3.90/4.10 - 237.99
Skip the 3.91, I'm not sure why you'd need to go with the 14/43 split instead of 10/39. I guess it might be stronger, more metal or something, but it seems like an unneeded expense.
Add to that another $120 for the install kit.
Old Apr 30, 2006 | 06:08 PM
outlaws318's Avatar
outlaws318
The Richmond gears sound pretty good. 3.90 gears will work. How do I get them?
Old Apr 30, 2006 | 10:27 PM
horatio102's Avatar
horatio102
www.summitracing.com - click 'online store' then 'differential and rear end components' then 'ring and pinion gears' and under axle model click 'show all' and select 8.375, that'll bring up the list. It is apparently the same part as the 8 1/4.
