Raising a '91 D-150....
Old Aug 1, 2006 | 02:36 AM
imstock's Avatar
imstock
Default Raising a '91 D-150....
Quick question... really...
Parts stores sell lift/lower kits for trucks, but that'd only lift/lower the back end with the leafsprings. Is there an easy lift/lower kit for the front shock setup on our trucks?
I am budget tuning at this point. :-)
Thanks.
Old Aug 1, 2006 | 02:46 AM
imstock's Avatar
imstock
Default RE: Raising a '91 D-150....
Lift Kit
Sould that work? I know thats a body lift and doesnt do anything for the suspension, but would it work? And how difficult is a body lift to do in your driveway? What do you need? Thanks!
Old Aug 1, 2006 | 04:02 AM
The Burning Rom's Avatar
The Burning Rom
I personally don't recommend body lifts. They're not safe in my opinion...to elevate the cab that much further away from the frame. It's fine if you're going to drive it carefully on the road. But if you're going to wheel it...or plow snow with it...or if god forbid you ever get into an accident, it's going to be nothing but a liability. Granted with a 2wd D150 you won't be wheeling or plowing...but accidents are still a possibility.
With that said, the lift does do what it's advertised. It will lift your truck.
As far as install, I haven't done any nor do I have any info for install on a 1st gen. But here's a write-up for a '97 Ram: http://www.pavementsucks.com/tech/bodylift.php It's not exact, but it will give you an idea.
Out of curiousity, why do you want to lift your truck?
Old Aug 1, 2006 | 02:19 PM
imstock's Avatar
imstock
Apearance. Not going to be 4-wheelin' or anything. Just want it to be more agrresive looking and ride a little taller.
Old Sep 12, 2006 | 04:59 PM
92ram150's Avatar
92ram150
you and me got a lot in common. i've got a 92 d150 i'd like to lift 2 inches.
Old Sep 25, 2006 | 02:07 PM
Captchnk's Avatar
Captchnk
I'm right there with yall. I want to lift mine about 2 inches as well. I have a 90 Dodge 150 V-6, short bed. If you yall find out a good way to lift it let me know? thanks.
Old Sep 25, 2006 | 05:57 PM
92ram150's Avatar
92ram150
i put the coilovers of a d350 in mine and it lifed the front almost an inch. it kind of leveled it out
