engine mounts
Old Aug 21, 2006 | 08:07 AM
89 ram man's Avatar
89 ram man
Default engine mounts
im swaping a 89 3.9 v6 with a 86 318 i was wondering what im supposed to do about the moter mounts can they bo moved or do i have to make some i didnt know if there is someone out there who has ever done this before thanks for any info
Old Aug 23, 2006 | 01:12 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: engine mounts
You usually can just move them on the frame. They don't make different frames for the different engines....they just put the moutns in a different spot.
The mounts should physically be the same between the 3.9 and the 5.2, since they're the same motor. The 3.9 is just cast with 2 less cylinders.
