Holley 500 on 2bbl intake?
Old Sep 9, 2006 | 09:31 PM
JohnnyW150's Avatar
JohnnyW150
Default Holley 500 on 2bbl intake?
Gentlemen,
Will a 500 Holley bolt right on a Dodge 2bbl intake (in my case 86 Dodge 318 2bbl)? My 86 Dodge still has the original carb but it's acting up. I'd like a little bigger carb to help with towing, otherwise the truck is bone stock minus dual exhaust.
Thanks,
Johnny
Old Sep 10, 2006 | 04:13 AM
cjsdad's Avatar
cjsdad
Default RE: Holley 500 on 2bbl intake?
I don't think so. I'm not an expert and I didn't stay at a Holliday Inn Express last night but when I swapped a 360 into my '85 W150 it had a Holley 500 on it and the mounting flange and bolt spacing were different.
YMMV!
Old Sep 10, 2006 | 05:12 PM
horatio102's Avatar
horatio102
you might be able to use an adapter, but no the 4bbl won't bolt directly up. The 2bbl is much smaller diameter.
Old Sep 10, 2006 | 07:41 PM
JohnnyW150's Avatar
JohnnyW150
Sorry I didn't clarify, the 500 Holley is a 2bbl. I've been kicking around with a bigger 2bbl or going 4bbl.
Old Sep 11, 2006 | 02:44 PM
horatio102's Avatar
horatio102
Oh. I'd go 4bbl with the oem iron manifold. You should see better idle/off idle response as well as perhaps a little better fuel economy since the primaries would be smaller.
Old Sep 11, 2006 | 07:11 PM
bigfoot2184's Avatar
bigfoot2184
"...little better fuel economy since the primaries would be smaller.".... not in my truck... lol
Old Sep 11, 2006 | 07:37 PM
rogertc1's Avatar
rogertc1
YES with an adaptor. I just removed my suckie 2BBL Carter and replaced it with a manual choke 500 cfm 2bbl Holley Carburetor 4412 . i used an adaptor from Summit
Carburetor Adapter, Open Center, Holley 2-Barrel Carburetor/Rochester 2-Barrel Manifold, .500 in. Thick, Each
$13.00
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 11, 2006 | 08:55 PM
JohnnyW150's Avatar
JohnnyW150
Rogertc1,
Thanks, how does it ride compared to the factory 2bbl? Any linkage problems?
Old Sep 12, 2006 | 08:21 AM
rogertc1's Avatar
rogertc1
I regretfully didn't ride her too far because I have some wiring problems. I found the Holley much more responsive that the Carter. and the Holley only cost around $200.00 for a very well rebuilt one. (A lot out there on e-bay).
I thought of going to 4bbl but didn't want to spend more $ on the changes to do it.
Old Sep 14, 2006 | 08:14 AM
rogertc1's Avatar
rogertc1
Default RE: Holley 500 on 2bbl intake?UPDATE
Got my electricle problem fixed///
Holley is great starts without even touching the gas.
I have to adjust the idol down a little.
Advise get a Holley manual choke cable off Summit. the one I got in the local parts store is too whimpy. Rreally gives the engine a clean look. Has a chrome free flow filter that looks great too.
I'll try a gas milage check today.
Roger
