Fan Removal
Old Sep 13, 2006 | 12:30 AM
dergani's Avatar
dergani
Default Fan Removal
I am trying to take the fan off my ram to get at the water pump. Does anyone know what size the nut holding the fan clutch/fan is? It looks to be maybe an inch or a little higher but I dont want to go and buy the wrong wrench.
Old Sep 13, 2006 | 11:59 AM
outlaws318's Avatar
outlaws318
Default RE: Fan Removal
wrench should be a 1/2 inch. Thats what I used to take my fan off and put the elec. fan on.
Old Sep 13, 2006 | 12:48 PM
dergani's Avatar
dergani
yes the bolts holding the fan on the clutch are 1/2 in BUT , i need to get the whole assembly off the water pump and there is a large nut inbetween the fan/pump. Do I need to loosen that?
Old Sep 14, 2006 | 09:35 PM
outlaws318's Avatar
outlaws318
Are you tring to change the Fan or the Water Pump? Because on my truck, as soon as I took all four of the bolts off the fan clutch, the fan came off and the water pump pulley came off to. Then I could get to the water pump.
Old Sep 14, 2006 | 10:39 PM
dergani's Avatar
dergani
I want to get the fan apart to sand it and paint it, and then replace the water pump. I am overhauling the entire engine and am dressing up at the same time while I have the thing apart. I need to get some more tools but it seems like the big nut inbetween the fan/clutch and the pump is what needs to be held steady so you can get enough support to break the bolts free without the thing spinning on you
Old Sep 15, 2006 | 02:26 AM
outlaws318's Avatar
outlaws318
Did you ever think of a flex fan, there about $30 or elec. fan. less drag on your water pump and add power back to the engine.
Old Sep 15, 2006 | 12:41 PM
dergani's Avatar
dergani
i will look into one of those
Old Sep 15, 2006 | 12:47 PM
outlaws318's Avatar
outlaws318
It works pretty damn good.
Old Oct 6, 2006 | 02:10 AM
dergani's Avatar
dergani
I got a flex fan but still cant get the stupid clutch off of the water pump , the big spacer bolt that holds it on wont move
Old Oct 7, 2006 | 06:36 PM
dergani's Avatar
dergani
I think maybe it turns counterclockwise in relation to the fan pulley?
