oil pressure?
Old Oct 21, 2006 | 10:51 AM
egll's Avatar
egll
Default oil pressure?
Hey, Newbie here. Just bought an 88 Ram 250, to be used as secondary plow vehicle. The engine (318) sounds great, that's why I bought it, but it carries low oil pressure. Can anyone tell me what the pressure should be? While I don't consider myself a "mechanic", I do feel capable of making most of the body repairs necessary to improve this ride.
Thanks for help,
Bob
Old Oct 21, 2006 | 01:20 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: oil pressure?
your oil guage should be around half or a bit below. if it's still the stock guage it could be that. what kind of oil do you use. I used 15w40 and 20w50 in my old ram and I had lots of oil pressure. how many miles is on her. it could be time to do a rebuild or you could just replace the pump.
________
Oregon dispensary
Old Oct 22, 2006 | 05:07 PM
horatio102's Avatar
horatio102
Pressure isn't always a good thing - you could put tar in it and have gobs of pressure but no flow. At idle once it's warmed up ~20psi or so is plenty. In my Ram it jumps to 45-60 when I get on the gas.
Old Oct 26, 2006 | 11:47 AM
egll's Avatar
egll
Thanks guys. The guage was bad, I replaced it. It carries from 30 at idel to 55 when on the gas. I feel much better now.
Old Nov 7, 2006 | 09:14 PM
jhouk2000's Avatar
jhouk2000
What all is involved with installing an aftermarket oil psi gauge on a 1985 360?
Where do I mount the sensor?
Is a mechanical gauge better?
What brand of gauge should I use?
