trans
Old Nov 29, 2006 | 12:03 AM
89d100man's Avatar
89d100man
Default trans
I have an 89 d100 v6 with 42rh, i was wondering if the 42re would swap in or if it has different mounting points or bell housing
Old Nov 29, 2006 | 04:27 PM
dodgedakotacrazy's Avatar
dodgedakotacrazy
Default RE: trans
a 42rh is hydrolic controled the re is electronically controlled..won't work...could make it work possible..but not worth it. should be the same...as far as bolting up as far as i know
Old Nov 29, 2006 | 06:06 PM
89d100man's Avatar
89d100man
Default RE: trans
if i were to swap in a late model v6 with 42re attached do you think that would be very cost effective
Old Nov 29, 2006 | 09:38 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: trans
then you would be left with finding a wireing harness for it too. I would just find the same tranny you have and put it in. or get yours rebuilt.
________
STOCK PICKS
Old Nov 30, 2006 | 12:49 AM
89d100man's Avatar
89d100man
Default RE: trans
Yeah I'll probably end up just rebuilding it, thanks for the help
