No Brakes - after sitting.
Old Nov 29, 2006 | 07:11 PM
1987PowerRam's Avatar
1987PowerRam
Default No Brakes - after sitting.
Started up the old truck that has sat since last winter (6 months or so)and after getting it running I pressed on the brake pedal to shift it into gear and the pedal lost all pressure and went straight to the floor.
With the truck running and someone else sitting in the seat pressing the brake pedal I can hear something under the hood and hissing and something steaming/smoking - must be spraying onto the engine- not sure...
Any ideas.. have had great luck with this forum so far figured I would toss that out..
Thanks again..
Old Nov 29, 2006 | 09:34 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: No Brakes - after sitting.
it's probly a busted brake line.
________
Medical Marijuana
Old Nov 29, 2006 | 10:46 PM
kurts2's Avatar
kurts2
I' second that!
Old Nov 29, 2006 | 10:47 PM
1987PowerRam
Thanks....your probably right.. time for the tow truck...
Old Nov 30, 2006 | 03:41 PM
horatio102's Avatar
horatio102
Can you see it squirting anywhere? I'd guess perhaps failed seal on the master cyl or maybe the booster gone bad. Did you check the fluid level?
Old Nov 30, 2006 | 11:04 PM
1987PowerRam
It was definately close to the MC and booster but I thought it was down lower but it was dark.. Fluid is gone now and tow truck is coming Monday... I had enough frustration with the steering column the last couple of weeks so I am going to let someone who has a clue do their thing... I am hoping its just a line though...
Thanks for the reply.
Old Dec 10, 2006 | 03:24 PM
1987PowerRam
All Fixed.. it was the line up front that runs near the manifold so that explains the steam/smoke I saw, the mechanic fixed a couple other spots while he was under there also. That truck has one rusty underside I tell you.. Next project is replacing that rusted truck bed.
