91 d250 4x2 318 help
Old Mar 2, 2007 | 05:34 PM
91rammer's Avatar
91rammer
Default 91 d250 4x2 318 help
[:@]I have a 91 ram d250 318 carb. my battery is new, alternater and voltage test out fine. Still wont hold a charge, Ive read that if all that checks out maybe the pcm is bad? anyone have this prob?
thanks alot
Ted
Old Mar 4, 2007 | 03:44 PM
wardcrx's Avatar
wardcrx
Default RE: 91 d250 4x2 318 help
Check the ground. Mine did the same thing forever. It was the ground that runs back up to the battery on the driver side. It was right under the hood hinge. The ground itself burnt. I put it back togehter and it worked fine.
Old Mar 6, 2007 | 05:28 PM
91rammer's Avatar
91rammer
the ground off the block? or is there another one? I changed out the ground to the motor, and no luck, about to try my new pcm
thanks again
Old Mar 7, 2007 | 12:24 PM
91rammer's Avatar
91rammer
Put in a new PCM and it cured all, my blinkers even work now, before I had to manually blink them
thanks for any help
Old Mar 10, 2007 | 05:47 AM
topsites's Avatar
topsites
ack nevermind...
