84 W150 D44 CAD
I am trying to find information on this. The only thing I could find is a Mile Marker hub kit.
http://ramchargercentral.com/index.p...owtoshow;id=78
I want to get away from the vacuum operated C.A.D. (Center Axle Disconnect).
I assume this MileMarker kit does that.
Does anybody know the product number for the M/M hub kit?
http://www.milemarker.com/hub-applic...plymouth-dodge
What is Selectro?
Been trying to find information for the past hour or so.
Ok I was looking the wrong way. This helps out alot.
http://www.4x4posi-lok.ca/
http://www.tellico4x4.com/index.php?manufacturers_id=72
Posi-Lok (PSL-450) = $160 USD *driver operated manual cable system*
Posi-Lok (PSL-1100) = $67USD *Permanent lock*
Nevermind, there are alot of Posi-Lok questions on this forum, I like the search function in this forum. Clears alot of things up for me now. Everything is much clearer now.
What is Selectro?
C.A.D. was used on 85-2001 Dodge 1/2 ton trucks (including RamChargers until 93). It was also used on 3/4 and 1 ton trucks from 94-02. CAD was Dodge's method of shift-on-the-fly 4wd engagement.
This helped me out alot, with the explanation of how the CAD system works. From http://www.ramchargercentral.com/boa...2573.msg356962
also
http://ramchargercentral.com/boards/...;topic=59727.0
also
