2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Uconnect
Old Jun 27, 2007 | 07:23 PM
Barry626's Avatar
Barry626
Default RE: Uconnect
ORIGINAL: fenderman
Barry,
Did you test the standard razor or just the v3m? I might just swap phones with my dad.
thanks
Just the V3m.
Just because 3 or 4 Motorola phones don't work doesn't mean all Motorola won't work?
I went thru 4 and 2 did not sync correctly when 2 others were perfect.
Tech. @ Verizon could not understand why some work & others don't.
Good thing I brought him out to my car so he could see exactly what I was talking about!
Old Jun 28, 2007 | 11:25 AM
fenderman's Avatar
fenderman
Thanks barry. I tested a standard razor and it works perfectly. I guess my free upgrade to a v3m was actually a downgrade, lol. Besides the standard razor and krazr are there any other verizon phones that worked?
Thanks
Old Jun 28, 2007 | 05:08 PM
Barry626's Avatar
Barry626
ORIGINAL: fenderman
Thanks
Glad to see u got one to work.
I know there was a nice LG but I forgot the model?
Some reason I'm thinking 9600?
If u go to Verizon in your area the tech more then likely will come out to your car with you?
Good luck!
Old Jul 3, 2007 | 09:33 PM
needforsleep's Avatar
needforsleep
I had a Moto L2 (SLVR with no camera) not pair with the Uconnect. I found that the issue I had was that it was already paired with the wife's Charger's Uconnect system so it didn't like the second system with the same name. I deleted the pairing for the wife's system and it still would not pair with the Avenger. I never got it to pair correctly with the Avenger.
On the other hand I can get my Moto U6 (PEBL) to pair with both cars' Uconnect systems. I guess I'm hitting on the point someone else made, which was not all phone's software/hardware work the same even if they are made by the same company.
Old Jul 11, 2007 | 11:31 PM
faba_2005's Avatar
faba_2005
im trying to get my bluetooth to work but when i hit the button in my car it says uconnect not available...why does it say that and what do i have to do to make it available.
my phone is a samsung SGH-D407 and i have cingular...just in case that is the problem...
Old Jul 13, 2007 | 01:42 AM
Barry626's Avatar
Barry626
ORIGINAL: faba_2005
Some phones dio not connect 100% correct with Uconnect. Not sure if yours is one?
Have u paired your phone with the car & the car with the phone?
Have u turned on the bluetooth in your phone?
Old Jul 15, 2007 | 05:25 PM
faba_2005's Avatar
faba_2005
ORIGINAL: Barry626
[/quote]
what do you mean by having my phone paired with the car and the car with the phone?
and yes i did have bluetooth turned on, on my phone.
Old Jul 15, 2007 | 11:33 PM
Barry626's Avatar
Barry626
ORIGINAL: faba_2005
ORIGINAL: Barry626
[/quote]
You have to push the "Uconnect" button (phone) on car & say "Pair Phone".
Be sure to have your phone on search mode. Phone & car will ask for 4 digit pin number.
Your manual should have all this info to pair your phone to car & car to your phone.
Good luck!
Old Jul 17, 2007 | 11:36 PM
faba_2005's Avatar
faba_2005
all it says is "uconnect not available"
Old Jul 29, 2007 | 01:31 AM
needforsleep
ORIGINAL: faba_2005
Are you sure you have Uconnect? That's typically the message you get when the feature is not installed on the car. I'd talk to your dealer. You don't have a pairing issue you have an issue with the Uconnect system not being recognized. For people who order the MyGig or the other radio without adding the Uconnect system this is the meassage you will get. The MyGig and optional radios do not automatically come with Uconnect, it has to be selected as an add on option.
