2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Performance chip?
Old Jan 18, 2008 | 08:57 PM
tlanger5's Avatar
tlanger5
Default RE: Performance chip?
Ya, there wasen't much expected of the whole thing by me - but for 20 i just had to see for myself...I took it off my car the next day after i put it on...Just curiousity - how does lets say a jet chip connect to the car? Does it just get plugged in somewhere?
Old Jan 18, 2008 | 11:43 PM
needforsleep's Avatar
needforsleep
The JET unit wires into your Throttle Position sensor and MAP sensor. It does essentially what adding a resistor does but it mostly likely can perform variable resistance changes based on throttle position. This is still not a true engine remap but it's one step better than a cheap resistor box on eBay.
This is not a real chip and since the gains are only 10HP max at the crank, it's not really worth it to me. The usefullness of this unit is that you could adjust it to maximize the benefits of adding on an intake and/or exhaust. They want $275 for this which is another negative. A real chip that was turned on a real car with a dyno will only run typically $300, so for this it's too much. If they sold it for under $100 I think it would be worth buying and playing around with.
Old Jan 27, 2008 | 09:48 PM
BadAssAvenger's Avatar
BadAssAvenger
Thanks for postin this question. I just bought the chip today. I'll let you know how it works out.
Old Jan 30, 2008 | 05:09 PM
kkzzr6's Avatar
kkzzr6
Does anyone know if the Jet plug in chips get rid of the top speed limiter? Jet hasn't answered my email.
Old Apr 30, 2008 | 01:15 PM
cfranz's Avatar
cfranz
I just put this in yesterday and bought it from http://www.autoanything.com/performa...;from_search=1
completly worth it.
Old Apr 30, 2008 | 04:21 PM
zeeman's Avatar
zeeman
ORIGINAL: kkzzr6
No they do not, but see my other thread about the predator tuner...This great tooldoes way more than just removing the limiter.
Old Jun 5, 2008 | 02:52 PM
DaZe831's Avatar
DaZe831
does anyone know if Jet still makes the performance chip for the 2.4l? i looked on the Jet website but couldn't find anything. thanks
Old Dec 20, 2012 | 01:56 PM
beezer86's Avatar
beezer86
for 300 bucks id say look around for a used nitrous kit....
