2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
chrome
Old Oct 27, 2007 | 07:12 PM
futil's Avatar
futil
Default RE: chrome
Obviously guns are recommended because you will have constant pressure, and a quality nozzle when you use them.. but you can achieve professional results using regular spray cans.
If you do buy a compressor and a spray gun remember to get a moisture remover/condenser and install it inline with the hose because compressors tend to spray moisture and sometimes oil from the compressor through the hose from the hotair cooling on exit from the compressor.. And the moisture can kill an otherwise professional spray job.
Something along the lines of this should be sufficient.. http://www.compressorworld.com/quick...13&xref=xx
Old Oct 27, 2007 | 09:28 PM
SueK's Avatar
SueK
Default RE: chrome
ORIGINAL: futil
Thanks very much. Excellent information.
