2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Washer Fluid Nozzle Replacement
Old Oct 19, 2011 | 08:20 PM
someguy13's Avatar
someguy13
Default Washer Fluid Nozzle Replacement
I've had my 2008 Dodge Avenger about a month, and the first time I went to use my wiper fluid, the driver side nozzle didn't spray. Upon investigation under the hood, I noticed the fluid tube hanging loose and the elbow nozzle connector had sheared off inside the hood.
It looks as though the elbow nozzle snaps into a seat within the hood.
Has anyone had a similar problem? Any tips on a quick fix? Is it possible to just rip out the seat along with the sheared off end of the elbow nozzle and replace, without causing damage to the hood?
Old Oct 1, 2012 | 07:15 PM
audezup's Avatar
audezup
Default washer fluid nozzle replacement
The elbow connector has broken off on my 2008 dodge avenger also. I am unable to find the elbow and I don't want to go to the dealer.
Have you fixed yours and if so, where did you get the elbow connector?
Old Nov 4, 2012 | 01:06 AM
someguy13's Avatar
someguy13
Autozone had a kit with everything I needed for $15 or so.
Old Nov 4, 2012 | 04:21 PM
audezup's Avatar
audezup
Thanks. I will go to Autozone.
