2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2008 Avenger headlight problem
Old Dec 9, 2011 | 11:35 AM
Swervn's Avatar
Swervn
Default 2008 Avenger headlight problem
I have a 2008 Avenger RT. Just installed HID low beams & HID fogs. The fogs work great just like they should. The low beams were flickering & shutting down. Today I just installed Dodge HID anti-flickering capacitors in line on the low beam circuit(plug & play). The low beams stopped flickering but they shut down & light back up. It starts with the right(pass) side. It shuts down for about 2 seconds & lights back up. It does this 2 times then the left side does the same. They stay lit fine for about 5 minutes then the right side only does this again. Does anybody know of a fix for this?
Thanks in advance...
Old Dec 10, 2011 | 10:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 2nd Gen Avenger section, The members there maybe able to help you.
Old Dec 11, 2011 | 09:31 AM
Swervn's Avatar
Swervn
Thanks...
