2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Transmission Help
Old Jul 20, 2013 | 08:43 PM
jlabelrecord's Avatar
jlabelrecord
Red face Transmission Help
I have a 2008 Avenger Se 2.4l and today driving home it sounded like my tranny was whiningpretty loud and it felt like it was almost slipping. Also when I stopped it the engine was louder almost like a truck it was strange. I checked the fluid but it was fine but the book said if its a fleet vehicle to do a tranny fluid service at 60k and Im at 54k could that fix it? Please help!
Josh
Old Jul 28, 2013 | 05:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If you still have a powertrain warranty, Get it to the dealer. The noise you are hearing maybe the transmission front pump. If you don't know if you still have warranty, send me a pm with the last 9 of your vin.
Old May 1, 2020 | 03:57 PM
Marxalot77's Avatar
Marxalot77
2008 2.4 l avenger, moves in reverse but nothing else? Was low on fluid. Not knowing any better I put in the wrong fluid. Is it worth a new filter and fluid to fix on a chance when i might need a new transmission?
Old May 1, 2020 | 09:53 PM
master tech
Did you put engine oil in or transmission fluid? Also did the check engine lamp come on when you were having this problem.
