2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
AC condensation drain line clogged
Old Jun 11, 2014 | 01:15 PM
dhub1220's Avatar
dhub1220
Default AC condensation drain line clogged
Just an FYI for any Avenger owners. I have a 2008 Avenger R/T. This would be the 3rd time in 6 years that the drain line for the AC has clogged. It had to be blown out with compressed air to clear it. When it clogs it fills the passenger floor board with water. Enough water to where if you place your hand palm down on the carpet the water will cover your hand. It's a 3/8 inch rubber hose for the drain which is a smaller drain hose than most vehicles. Maybe that's why it clogs easier than others.
Old Jun 11, 2014 | 06:09 PM
MoparMan1991's Avatar
MoparMan1991
Even then it shouldn't clog up. Is the drain line level or is it angled?
Old Jun 11, 2014 | 06:39 PM
yaquindn's Avatar
yaquindn
if you can get under the car use a drain snake to clear the line. I've had luck doing this to several of my cars and trucks
http://images.lowes.com/product/conv...12004004lg.jpg
Old Jun 24, 2014 | 02:38 PM
mzprs's Avatar
mzprs
New Member
Could this also cause a wet spot on the driver's side floorboard only? it is only wet beneath the gas pedal
