2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
oil pan gasket help
Old Apr 9, 2015 | 08:07 PM
dnoishere's Avatar
dnoishere
Default oil pan gasket help
...2008 Avenger SXT 2.4 "K" vin...so I think I've got a leak. Got the Fel-Pro gasket set...comes with the rtv sealant...how/where do I use the rtv? on both sides of gasket?
Also, says it takes a hour to dry, 24 to cure... so how long do I wait to fill it back up with oil and run? Thanks for any and all help and guidance...
Old Apr 11, 2015 | 02:47 PM
dnoishere's Avatar
dnoishere
...really...no replies or helps?
Old Dec 30, 2015 | 05:09 PM
slackjawedloser's Avatar
slackjawedloser
Obviously I am a little late, but for others, I found this:
http://www.felpro-only.com/break_roo...ad.php?tid=451
and this:
http://www.autozone.com/repairguides...96b43f81b3c64f
Old Dec 31, 2015 | 07:18 PM
lxman1's Avatar
lxman1
Site Moderator
I usually use the RTV on the part side of the gasket and none where it goes against the engine.
