2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Radiator cap Tee replacement.
Old Dec 13, 2016 | 12:30 PM
avenjeeperger's Avatar
avenjeeperger
Default Radiator cap Tee replacement.
Just had the radiator cap Tee break on my 09. The parts people said there was no replacement and that I had to get the upper radiator hose assembly for $60+-.
Nonsense! The Caliber has the same part and you can get it at AZ or Advanced for $24.
Old Dec 13, 2016 | 01:35 PM
You can buy one from there and try it out. If no go, return it.
Old Dec 14, 2016 | 07:08 AM
avenjeeperger
Not a "try it" situation. It's the exact part needed. As long as the hoses are in good shape you are all set. Even has the clip so it sits in the metal bracket.
Coolant filler neck
