2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Alternator or battery?
Old 02-01-2018, 06:24 PM
Zombifyd's Avatar
Zombifyd
Zombifyd is offline
Default Alternator or battery?
Hello, my wife's car (2014 avenger, 2.4) recently had all the dash lights blink on and then off and the traction control light stays on. Also the radio lights turn off and back on. She went to advance to get the battery test and they told her that the battery reads too low for an answer. I was told it could be the alternator from an avenger group on facebook but i was hoping for a second opinion before I replace the alternator this weekend. (I heard a surging alternator can harm the ecu.)
Thanks
Old 02-01-2018, 07:36 PM
jkeaton is offline
Dodge Forum Administrator
Stick a voltmeter on the battery with the engine running. Should be @14.5 VDC. If so, the alternator is good.
Old 02-01-2018, 09:28 PM
Zombifyd's Avatar
Zombifyd
Zombifyd is offline
Directly to the battery? Because its in the fender. Would i get a good reading from the positive post that leads to the battery and a good ground?
Old 06-12-2019, 08:34 AM
beech2000's Avatar
beech2000
beech2000 is offline
Thanks
Our 2013 has the same symptoms as yours. Did you ever figure it out?
Old 06-18-2019, 10:59 PM
300Guy's Avatar
300Guy
300Guy is offline
My 2012 just had the battery and alternator fail and all those lights were on as it failed. It failed within 30 to 40 minutes and never once gave us any indication the battery or anything was bad!!!!!! Guys told me when the battery gets bad, the alternator takes over and eventually the alternator overheats and takes out the rectifier. My opinion right now is there is a very poor design if this is happening to other people!!!!!
Old 06-20-2019, 07:45 AM
jkeaton is offline
Can you design a better one?
Quick Reply: Alternator or battery?
